sim card not working
emilyflemming1
i had bought a sim card, set it up for my girlfriend, the payment went through and everything. i've tried the sim card on the phone she has, and my old one that was also with public before i got my new one, and it just keeps saying no sim card. what do i do?
ddeep91
@emilyflemming1
You can try removing the SIM and re-inserting it.
As you said you have used the second phone with PM before it could be that sim card is faulty?
Usually, that's not the case but it could happen.
If you have already tried turning the airplane mode on/off, restarting the phone, take the sim card out and reinstalling the sim card and it still does not fix it.
If you bought the sim card online.
Then I would recommend you get in touch with the moderators to have this issue looked into.
1)Click on the green question mark in the white circle at the bottom right of your screen.
This connects to the Autobot Simon.
2)Type moderator and follow the prompts to get to one (CLICK on the "account-specific" question and human and submit a ticket)
Or contact them directly using this  Moderator_Team.
In your message include:
- account email address, pin number
- PM phone number
Hope this helps
Cheers
Dunkman
@emilyflemming1
Maybe try rebooting phone with PM Sim card.
Which model phone does your friend have?
Maybe try the SIM card in your phone?  To determine whether hardware issue versus PM service issue.
LovesToPM
So you've tried 2 SIM cards and both say "no sim"?
Looks like her phone is not detecting the SIM card. Is there another SIM card you can try to confirm (your current SIM or her old SIM if she has one?)
If problem persists, you can try attaching a piece of tape on the back on the SIM card so it improves the contact.
Triguy
Is the phone unlocked ?  If you have another phone then try putting in it.
