02-25-2019 06:48 PM - edited 01-05-2022 06:44 AM
Hey I’ve been trying for approximately 8 hours to get my SIM card to work in a Samsung s8 I bought.. Ive even changed the apn settings to what that should be but it is not working and support for public mobile is garbage. what Can I do to fix this before I switch providers
02-25-2019 07:37 PM
This happened to me as well. Your phone is likely locked by your current provider and that is why it is not recognizing your sim. You'll need to get it unlocked from your current provider in order for the public mobile sim to be recognized. Mobile devices have to be unlocked free of charge so you'll just need to contact your current provider and get it unlock and you should be good.
02-25-2019 07:27 PM
If nothing is working, checking apn will do nothing. Is the phone unlocked? Any error message? Try your sim in another phone and also try a friend's Public sim in your phone.
02-25-2019 06:57 PM
You can already write a message to the moderator here...
and explain your problem. And during the waiting time try the tricks the others can tell you..
02-25-2019 06:55 PM - edited 02-25-2019 06:57 PM
@JessieB - what is the error you are getting? Is there a message?
EDIT: just noticed that you said SIM not recognized
Any chance the phone is locked? Was it new?
02-25-2019 06:53 PM
02-25-2019 06:52 PM
I’ve been trying to reach support but the only thing I can reach is the robot... to message the moderator team says it’s not found... in my new phone it says SIM card not recognized.. yet it transferred my contacts over.. I’m beyond frustrated at this point
02-25-2019 06:50 PM
apn settings is for data
where did you get the phone
are you sure the phone is not on the black list
did you change the sim card and make it active in your self serve account
02-25-2019 06:50 PM
have you checked the sim in another phone?
02-25-2019 06:49 PM
does it say no sim card?
02-25-2019 06:49 PM
@JessieB wrote:Hey I’ve been trying for approximately 8 hours to get my SIM card to work in a Samsung s8 I bought.. Ive even changed the apn settings to what that should be but it is not working and support for public mobile is garbage. what Can I do to fix this before I switch providers
@JessieB support is not garbage, you can send them a private message
otherwise, try putting a pc of tape on the sim
