sim card activation
farter
my account is paid and active, got a new phone, will not recognise sim card, mobile network setting is greyed out?
9 REPLIES 9
@farter
try both of these two things:
  • put the Sim card in another device to test SIM
  • use another working SIM card in your new phone to test phone
@farter   your phone should work on PM
First, check devicecheck site and let us know if the phone is clean
If clean, try a reboot and the Reset All network settings to see if it works
farter
Its a Ulefone ARMOR X10 to replace the Armour X8 that i was very happy with.
@farter wrote:
i bought it from amazon, there is not even a phone icon to dial with
@farter  first , check if your phone is clean or blacklisted
Also, tell us what brand and model is your phone
farter
@farter wrote:
it's a brand new phone, came with a notice that i might have to manually input the APN, but it would not respond and greyed out the mobile network setting
@farter  The APN will only affect your data, won't affect connection or voice
Where you got the new phone from?  please check if your phone is clean here:
https://www.devicecheck.ca/check-status-device-canada/
@farter
What happens when you dial *611?
Can you try the SIM card in a different device?
 Also, try resetting network connections and rebooting device with SIM card in it.
farter
HALIMACS
@farter
is it new to you, or a brand new phone
EDIT:  if used, make sure it’s not locked to a prior carrier or blacklisted.  To check blacklist:
