10-24-2022 08:12 PM
hey guys,
im in trouble here, i bought the sim card and activated it back in may this year from a small shop now i have no use for the service anymore and i would like to cancel it but i can not disable my payment method through my credit card because i can not log in! i dont have the 4 digits pin number and i dont know the email associatied with the sim at the activation time 5 months ago, all i have is the sim number it self it has a 19 digits on it and my credit card that is linked to the account, the only option i have is to compromise my credit card which is going to be a pian in the neck i really dont want to go through that!
Can someone help me please...
Thanks million
Service
10-24-2022 09:27 PM
@Moe75 that's great to hear!!
10-24-2022 09:27 PM
i lost that paper, thank you for your help
10-24-2022 09:26 PM
thats also a good option thank you so much
10-24-2022 09:26 PM
thank you so much for providing me with their email, i was able to contact the agent and he solved the problem
10-24-2022 08:28 PM
Didn’t the store print out all the information…email address, PIN etc?
You can dial 611 and disable AutoPay…let it run out after 90 days so your account will be cancelled/closed.
Or contact a CS_Agent to help you access your account.
10-24-2022 08:21 PM - edited 10-24-2022 08:22 PM
On the day prior to your next renewal (around 5PM ‘ish), put your credit card on a temporary hold.
The renewal will fail, and your PM service will suspend.
10-24-2022 08:19 PM
@Moe75 hi if you can't get into your account and you don't know your pin contact a customer service agent to remove your card for you
private message them here
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
