11-24-2023
09:51 PM
11-25-2023
02:02 AM
computergeek541
i ported out from my telus plan to publicmobile, but nothing has worked as of yet.
it gives me sim1 not provisioned, can't make calls, or have any data.
I got the you're all set email at 8:30pm
11-24-2023 09:52 PM
HI @spizy is that physical sim or eSIM?
if physical sim, try it on another phone
But if that is eSIM, check your phone and make sure eSIM is installed and active
if same, submit ticket with CS agent for further help here
