09-08-2022 03:54 PM
09-09-2022 01:30 AM
open ticket with PM support and ask them
At https://publicmobile.ca/chatbot.
have trouble with Chatbot: Private message CS Agent at:
Once ticket is submitted,(envelope icon on the top right) CS_Agent will reply you there.
Reset All Settings not works do backup and Hard Reset.
09-08-2022 04:02 PM - edited 09-08-2022 04:04 PM
@Citoyen Might be because of some some network issues or an outage in your area or just a temporary issue which should get resolved by itself later in the day.
If you're having issues with calling, try setting your phone on 3G/WCDMA mode temporarily. Or try rebooting a couple of times. If possible also try your SIM in another compatible phone to rule out a device problem.
09-08-2022 04:02 PM
Mine too. It one bar less.
