04-07-2019 08:52 PM - edited 01-05-2022 04:13 AM
I'm having some trouble. I just got the plan today, as well as joined PM for the first time and I'm unable to send or receive picture texts. Mind you, this is my first time being able to send pictures ( I was not able to with my previous provider). Is there something in my settings I need to look over for this to happen?
04-22-2019 12:30 AM
@disneybear15 wrote:It's unfortunately not working...
the only difference I've noticed is that "MMSC Proxy" is "MMS proxy" on my phone... does that make difference?
same thing
04-21-2019 10:24 PM
Hi @disneybear15 ,
I cannot be sure this is going to make a difference, but on this page you will find settings for different phone models, but all of them for use on the Public Mobile network. This would seem to indicate that some phones would use slightly different parameters. It may be worth having a look to find the exact parameters for your specific phone. Jsut scroll down the page to just under the video, you'll find the section "Select your phone model to get device customized Public Mobile APN settings". Let us know if it works !
04-21-2019 10:10 PM
04-15-2019 10:43 PM
@computergeek541 wrote:
@disneybear15 wrote:So will sending pictures via text come out of my data usage?
No, MMS will not count towards your data usage.
...and that's really cool ! ![]()
04-15-2019 10:41 PM - edited 04-15-2019 10:41 PM
04-15-2019 07:53 PM
04-08-2019 02:27 AM
Remember with picture/MMS (Multimedia Messaging Service), you need "Mobile" data; wifi data alone does not work for MMS.
04-07-2019 09:01 PM
@disneybear15 wrote:I'm having some trouble. I just got the plan today, as well as joined PM for the first time and I'm unable to send or receive picture texts. Mind you, this is my first time being able to send pictures ( I was not able to with my previous provider). Is there something in my settings I need to look over for this to happen?
In addition of having correct APN settings, don't forget to enable data before sending any MMS. You can disable data if you don't need it afterwards.
04-07-2019 08:55 PM
The most likely cause is the APN. You need to configure (Or re-configure even if you have already configured before) your APN settings to be able to send pictures (MMS) and navigate on internet (DATA). Your "Mobile Data" needs to be activated.
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Iphone
Settings > Cellular > Cellular Data Options > Cellular Network
OR
Settings > Mobile Data > Mobile Data Options > Mobile Data Network.
Name: Public Mobile / Mobile Internet
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Select Save/Done. Select Public Mobile to connect to the Public Mobile network.
04-07-2019 08:54 PM - edited 04-07-2019 08:58 PM
@disneybear15 , I have moved your question to it's own message thread.
This would be a good place to start, although slight modifications might be needed to these settings based on your specific phone modlel and software: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...
