05-07-2023 02:21 PM
OK I have an account with Public it works well $25.00 plan. I have 2 sim cards from public the one i use the other still in package. Can I get a second account with new number and just switch between sims.
Service
05-07-2023 04:22 PM
you sure enough can.
You need a fresh sim and start a fresh new account. Make sure to use a different email address but gmail alias works fine. You can use the same credit card for payment if you like.
Get an old unlocked phone for your 2nd sim rather than changing each time.
05-07-2023 04:22 PM
YES you can - and don't need a dual SIM card phone -Just simply remove and replace Sims as required.
05-07-2023 04:20 PM
ok i found out i only have single sim since mobile dosnt support esim can i activate second public sim take the main one out put second one in and switch back and forth that way? tyvm
05-07-2023 04:01 PM
ok i found out i only have single sim since mobile dosnt support esim can i activate second public sim take the main one out put second one in and switch that way?
05-07-2023 02:30 PM
05-07-2023 02:28 PM
tyvm 4 u help
05-07-2023 02:27 PM
I believe I have Esim as well and dual sim dont know if phone unlocked from public tyvm for your help
05-07-2023 02:23 PM
for a second number..you need a new sim to start a new account. Only 1 number per account.
If you have a phone with dual sim slots, you can use both sims and go between each account.
05-07-2023 02:22 PM
Yes, you can @webspy007
As you indicated, they'll each need their own account and email address when activating.
But you can use the same payment card for each of them.
