roaming while in US to Canada
janice123
I asked for 8.00 roaming talk and text to call from US to Canada. I have a Canada phone number. I am not able to dial out. Did I buy the wrong one. Should I have bought the 10.00 US roaming talk and text?
janice123
Thanks so much!
geopublic
@janice123  Access your selfserve account and check on the landing page does it show any US Roaming add-ons?. PM offers an $8 Talk and an $8 Text US roaming addon. If you have the text only then you can only send/receive texts.
Here are PM US Roaming add-on available for purchase:
Do you see the amount added in your Available Funds? If so then you need to go back and actually purchase the add-on. It's kinda non-intuitive.
Either that or manually scan for and connect to either AT&T or T-Mobile.
Jb456
Stay safe
There are no talk and text roaming add-ons priced at $8 or $10.
I suspect that may have purchased an $8 long distance add-on that is for use while you're in Canada.
There is a U.S. roaming talk add-on for $8, and there is also a U.S. roaming talk and text add-on for $15.
