05-03-2022 06:13 AM
what are the roaming plans and cost for making & receiving calls in usa?
Service
05-03-2022 02:29 PM
You can also use 611 or 1-855-4pu-blic to add money and buy roaming add-ons. This can be done in the states too.
05-03-2022 02:27 PM - edited 05-03-2022 02:28 PM
This is how, @SN3 :
To purchase Add-Ons using your Self-Serve account, follow these steps:
- Click on ‘Purchase Add-Ons’ on the Overview tab and scroll down to the Add-On calculator.
- Click the plus sign (+) to add and the minus sign (-) to remove selected Add-ons.
- When you’ve added the desired US Roaming Add-On, click ‘Buy Add-Ons’ or ‘Make a Payment’ below the calculator:
- You will see ‘Make a Payment’ instead of ‘Buy Add-Ons’ if there are not enough funds in your account to make the purchase.
- If you don’t have sufficient funds to purchase the Add-Ons, you will be asked to make a one-time payment equal to the price of the Add-On, less your current available funds. Click ‘Submit’, then ‘Go back’: now the button below the calculator will say ‘Buy Add-Ons’.
- Select ‘Confirm my purchase’, and you’re done.
- Some users have found that rebooting the device is required afterwards.
05-03-2022 01:42 PM - edited 05-05-2022 06:01 PM
Are you in the US or leaving for the US today?
To contact customer support :
Submit a support ticket via Simple--Simon the chat bot Click here
Or if you prefer or cannot submit a support ticket you may send a private message : Click here
To pre-verify add in your private messaging only your full name, address, email, phone # & 4 digit account pin #
05-03-2022 01:33 PM
This is self serve. Log in and add the money then buy that add-on. It's 2 steps.
05-03-2022 01:30 PM
I would like to add today the 10 day USA roaming package for voice, text & 250MB data for $20
05-03-2022 06:36 AM - edited 05-05-2022 06:10 PM
Here is some additional info on US Roaming you may find helpful in addition to the pricing structure supplied by @HALIMACS . If you are on the points program redeeming points for add ons offer up to a 50% discount on the equivalent $$ price.
Here is some info about US roaming add ons that should help you.....
- While you have to have an active plan to purchase and use US roaming add ons the type of plan you have does not affect the roaming add ons features.
- US roaming add ons start the moment you confirm and submit your purchase in your self serve account and expire 240 hours later (10 days×24 hours).
- You can pre-load the funds needed to purchase the add ons in your self serve account so you only have to log in, select the US roaming add on and then confirm and submit your purchase.
- Wait til late as possible to purchase since they are immediately valid so on free wifi at the destination airport or stopping shortly before the border at mcd's or timmy's to buy the add on while on free wifi.
- If you are staying longer than 10 days you must wait a minimum of 24 hours to purchase the same US roaming add on or contact the moderators to add it before the waiting period ends.
- If you have two US roaming add ons with a talk feature that overlap the talk feature basically gets disabled. Avoid this....but you will have to get one removed by a moderator to get your calling feature back if this happens.
- After purchase reboot your phone and manually select either at&t or T-mobile to get better reception. Some areas have better coverage by either provider so when travelling around the US you will be better served by choosing the provider with better signal strength by locale.
- You will recieve incoming texts without any US roaming add ons. Adding a voip app like the fongo app and/or textnow app for use on wifi are good to use for a back up plan or if you are only using a US Roaming data add on only. If you will be using a local SIM card you could call forward your pm phone # to your voip # before you leave Canada and remove your pm sim card so it does not connect to a US cell tower and erase your call forwarding. A voip app also works on mobile data using a fairly minimal amount of data for voice calls. (1 min=0.5mb/100 min=50mb)
- All US roaming add ons have either unlimted text, talk or both. Only data has limits depending on your purchase 250mb/500mb/1gb. Once the data is consumed it will just stop you could then purchase different roaming add on, wait 24 hr to buy or contact the moderator to buy the same US roaming add on again. (* except talk as previously mentioned.)
Happy travels and Stay--Safe!
Please note currently due to the decommissioning of the 3G network in the US by pm's roaming partners at&t has already begun this process but as of March 3rd 2022 still has some areas that are still served by the 3G network. T-Mobile has an end date of July 1st 2022. This will affect the ability of pm customers to send and receive voice calls and emergency service such as 911 while in the US and using pm's US roaming add ons. The current work around is to download a voip app such as textnow or fongo for use while on wifi or mobile data for voice calls when in areas no longer served by the 3G network which will eventually include all areas served by at&t and T-Mobile.
05-03-2022 06:20 AM - edited 05-03-2022 06:24 AM
10 day packages
U.S. Talk, Text and 250 MB Data bundle: $20
U.S. Talk and Text Bundle: $15
U.S. Talk Only: $8
U.S. Text Only: $8
10 day packages
250 MB: $10
500 MB: $15
1 GB: $20
