rewards
04-26-2023 02:14 PM
I referred a friend who stayed with public mobile for 4 months. However, I stopped getting the rewards after 4 months.
Rewards
04-26-2023 11:38 PM
If your friend’s account is suspended or ported out of PM…you won’t receive the reward. Check with them.
04-26-2023 02:25 PM
So what’s your question?
04-26-2023 02:16 PM
@nk6 Did your friend leave PM after 4 months? If so then yes you'll stop receiving rewards when they've left.
04-26-2023 02:16 PM
When the referral leaves then the reward stops.
04-26-2023 02:16 PM
HI @nk6 ask your friend if he is still with Public Mobile
Also, if it missed a payment, and happened to be around your renewal, it might be why you don't get it. But if it pay again, then you will get the rewards again
and you are on old rewards or new Public Points.? If old, login to My Rewards and check if his number is still showing up
