My Account
Minnedosa
I have logged into my account but, I have not received an email to verify myself...now I am locked out of my account.
Any help would be appreciated.
Minnedosa
I will try that, thank you.
@Minnedosa
Try using a different browser but clear cache and go incognito first before trying to login.
If that didn’t work, just wait for a reply from a CS_Agent tomorrow.
Minnedosa
Hi, I'm waiting for the email..it never arrived (checked the spam folder). While waiting for the email, the verification has said too many attempts. I have not received an error code either.
@Minnedosa
You can receive a 2FA code by text only if your account is Active. If your account is suspended…your only option is by email.
Minnedosa
Thank you, I have opened a ticket.
@Minnedosa   You try to login to My Account but cannot didn't get the 2FA code?
is getting it via SMS an option?
if not, and you unable to login, then you will have to open ticket with PM support for help
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
