rewards redemption
RM81
How can I get help with a public points redemption that has been stuck in pending for 4 days?
Were you using the app to check? Try using browser with incognito mode and check
will13am
@RM81 , I have had redemptions stuck in pending before.  Usually the pending is removed after a day.  Support will process it immediately for you.
RM81
I redeemed a data add-on. It still says "pending" 4 days later (and is not on my account). I did receive a confirmation email. I have now also submitted a ticket.
TheSterlinger
Redemption are usually applied immediately.  What do you mean stuck? Did you you refresh the site?
Which one did you redeem?
