Can I change plans in different months in Public Mobile?
JimmyZheng
@CSA_PM wrote:
The plan can be changed whenever you want. Just keep in mind that you can change always to in market plans.
I wish the above were true, but as we already know, that's not always the case.  Public Mobile is now very selective to the plans offered to existing customers, and even currently offered plans are not offered to existing customers much of the time, especially if it's a lower priced plan.
CSA_PM
Customer Support Agent
Hi
The plan can be changed whenever you want. Just keep in mind that you can change always to in market plans. Once a plan is expired you cannot get back to it.
@JimmyZheng  You can change plans when ever you want and set it for next renewal to avoid losing $ or you can always do immediate plan changes at any time and will start new 30 day subscription as soon as you make payment . But also note it’s not always so easy to downgrade plan price always easier to upgrade plan price so choose wisely and just stick to what you need and try not to get seduce. By bigger data bucket plans that you don’t need for 1-5 $  more a month is my advice
hi @JimmyZheng
can you explain what you meant by different months?
you can use Change on Renewal to change plan on coming renewal.  But remember, after plan change, you might not be able to get back the old plan you had.  So for example, if you just want to change to a US roaming plan for summer months only and go back to the old plan, you can't.
