06-09-2020 08:13 AM - edited 01-05-2022 11:37 AM
is it possible to reuse a email address from deactivated accounts? i dont want to create any new emails but want to move back to public mobile.
would be really nice if you allowed multiple lines under one email.
06-09-2020 09:22 AM
@akafred The workaround is to use an email alias. If you use Gmail the you can use aliases.
06-09-2020 08:43 AM
Given how the event promotion is tied to an existing email address, I would say it is now possiblev to reuse an email address. It is should be pretty easy to find out during the activation process.
06-09-2020 08:38 AM
You can also use the "." to make more Gmail address. Like [email protected] and [email protected] go to the same address.
06-09-2020 08:31 AM
You can use one Gmail account with 2 or 3 aliases fore example [email protected], Alias #1 [email protected], #2 [email protected]. Just make sure it doesn't go over 30 characters. There have been complaints of emails longer than that not being accepted at activation.Welcome back.
06-09-2020 08:29 AM
Hi @akafred
I used the same email before
It's not supposed to work but it did, so you could try. I expected the error but activation went through
Did you get that come back offer? In that case you must use the same one
You could contact moderators for help https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 if it won't work.
If you use Gmail you can use aliases, name@gmail will receive messages for n.ame@gmail or name+124@gmai
But to accept that offer you must use the same address
Welcome back:)
06-09-2020 08:27 AM - edited 06-09-2020 08:29 AM
Entire Public Mobile accounts never get "deleted". The best you could possibly hope for would be for Public Mobile to allow the future use of an e-mail address. There's actually a promotion right now for some former customers that requires the customer to activate using the same e-mail address as before.
06-09-2020 08:24 AM
is there any plans on ever allowing old accounts to be deleted? this is a major downfall to public mobile. between all previous and current accounts i have like 5 emails used up.
06-09-2020 08:18 AM - edited 06-09-2020 08:33 AM
No @akafred you need a new unique email address. You can't reuse one from a deacitvated account. Welcome back. Stay safe.
Here's 4 articles on activation and porting and the Refer a friend reward if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
06-09-2020 08:17 AM
You would need to use a different email.
