Texting is not working
Shreef
My SMS massages is not working, i can receive them but can't send them
10 REPLIES 10
@Shreef
I quickly checked the specs on the phone.  It should work with Public mobile.
https://www.fonearena.com/huawei-nova-3e_8777.html
Were you able to try the SIM card in another working phone?  This helps determine whether it is a hardware issue versus PM service problem.
I assume that talk and data work properly?
Might want to try a network reset on your phone.
@Shreef wrote:
Thank you all for the replies, unfortunately my SMS massages still not working.
My phone is an android (Huawei Nova 3E), I have the 50$ plan.
I was told that someone will contact me in 48 hours, but no one really did.
I have tried rebooting my phone and even changing the phone, but still no result.
@Shreef  What app are you using to send text? Can you try it using Goggle Messages. If you submitted a ticket to PM you need to keep checking your email icon for a private message response from the Moderators.
Shreef
kselmak
What happened when you tried?
What is the status of the message you tried to send?
Is it too any number or a specific one?
Can you test it with a native/different messenger?
Can you test it in the different phone?
geopublic
@Shreef  What is the make and model of your phone?
Do you have another phone that you can try your sim in?
gblackma
@Shreef  try force closing your text app and restart your phone.  Wait 30 seconds and restart it.  Welcome to the community.  Stay safe.
@Triguy
SMS doesn't use data.
Triguy
What type of phone do you have ?  Make sure data is turned on.  Try rebooting your phone.
I would ensure that your SMSC is set to +16475800172.  In some text messaging appications, the setting is sometimes referred to as message center.
If you have the old $10 plan maybe you're out of texts.
If you have an iPhone make sure SMS is set to on in iMessage.
Is this for one recipient or all?
