remove add on
jenniferyang
Hello,
I accidently purchased US Roaming - Unlimited Text (10-day). I was to buy 200 min US and Canada Long Distance. How can I cancel this US Roaming - Unlimited Text (10-day) and get refund? I did not use it yet. Thanks.
1 REPLY 1
will13am
@jenniferyang , you will need to reach out to the moderator team to make the correction for you.  The moderator team can be reached via private message using this link.  Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
