01-10-2024 07:51 PM - last edited on 01-11-2024 07:26 AM by computergeek541
I want to obtain a recycle number. I lost my phone and it's been 120 days since last payment on my PM account. What is the possibility of activating a new sim and selecting the same phone number?
Thanks
01-10-2024 08:27 PM
I will try if all else fails
01-10-2024 08:26 PM
Great! thanks!
01-10-2024 08:26 PM
That's EXACTLY where I was going with my earlier Bell comment experience, @Void
I'm thinking there's a better chance that TELUS could draw upon the number, however, that would mean the OP would have to initiate a service with TELUS, then port the number over here to Public Mobile.
01-10-2024 08:23 PM
Thinking out of the box, if PM can't get the number back, and if it is that important, OP could try Telus next. That'll mean he likely need to open an account with Telus, though.
01-10-2024 08:22 PM
@JS_SOS Also note you can change number 4x for free every 30 day cycle . And you can search through the pool of numbers by refreshing the page in your account profile page . If you end up creating new account anyways because of it came from PM and no one else has it it will come back to PM
Change # on profile tabs
01-10-2024 08:21 PM
Number was assigned by PM... thanks
01-10-2024 08:19 PM - edited 01-10-2024 08:19 PM
To be certain @JS_SOS , are you claiming the number was ORIGINALLY assigned by Public Mobile, or was there a chance you moved to Public Mobile from another provider when you first moved services here?
01-10-2024 08:18 PM
@JS_SOS YES thank you 🙏
01-10-2024 08:17 PM
thanks ...no worries it's worth a try!
01-10-2024 08:15 PM
Some carriers (tiers) may have greater capabilities to draw upon numbers from their available pools than others. Bell can do this, for instance. (at least they could for me SEVERAL years ago ...)
The reason we might offer that piece of advice is in cases where a user is wanting a number which 'belongs' to another carrier, but they are wanting to use that number with a different carrier.
In that case, it's impossible as the different carrier doesn't 'own' that number.
In this case, the OP is suggesting the number was originally assigned by Public Mobile (meaning they did not port it here from elsewhere). Does that mean there's a greater change, maybe, however I still believe it extremely unlikely.
Do I like your optimism, sure. Go with it !!!
01-10-2024 08:12 PM
I called and the automated message indicated that the number was unavailable. I sent a inquiry through private message To CS_Agents.
Thanks for everyone's assistance... wait as see for now
01-10-2024 08:08 PM
@HALIMACS Well why when people lose number they want back we advise to try with the carrier it came from?? And I did mention about calling it to see if it’s already been given out . but why even bother to say that if you believe there no chance in getting back ? At end of the day @JS_SOS we are just customers like you trying to help one another . Sorry if I gave you any sorta false hope . But I offer you exactly what I would do in your shoes . Best of luck
01-10-2024 08:02 PM - edited 01-10-2024 08:22 PM
So... @will13am is likely correct in their assertion, and I'm surprised that @Handy1 would surmise there's a chance to regain the same number. (EDIT: but good for Handy1 for sharing some good vibes 😂)
Try calling the number to see what happens - that's your first step in assessing it's current use.
Other than that, if the customer support agents are REALLY able to give you a specific number, that's a game-changer around here. Please do share that success story, if you would ...
01-10-2024 07:59 PM
@JS_SOS You could also start by calling your old number and see if Someone answers . If they do then unfortunately the number is gone . And if not then maybe contact support .
01-10-2024 07:57 PM
It was PM... thanks I'll try the link you provided!
01-10-2024 07:56 PM
I need this number... thanks
01-10-2024 07:55 PM
@JS_SOS , I am not exactly sure what you mean. If you have let your old account go dormant for this long, the account will have been deactivated and the old number has gone back to the pool for recycled use. Your chances of getting that number back is probably slim to none. If you are okay with getting a new number, you can activate a new account and select from a pool of available numbers.
01-10-2024 07:53 PM - edited 01-10-2024 07:53 PM
@JS_SOS Could be like searching for a needle in a haystack . Where do the number originate from was it Telus Koodo or PM ?? If it is there’s a chance but you would need to ask support or go to carrier the number came from to try and get back if it hasn’t been reassigned to somebody else
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
