03-06-2023
12:58 PM
03-06-2023
01:00 PM
computergeek541
03-06-2023 01:17 PM - edited 03-06-2023 01:17 PM
03-06-2023 01:16 PM
Incoming doesn't matter to you. The long distance factor is on the caller, not the recipient. If the space station could dial direct to a terrestrial phone system then you could receive that call too at no charge to you.
03-06-2023 01:14 PM
So, I don't need to purchase any add-ons to receive incoming long distance calls?
03-06-2023 01:09 PM
03-06-2023 01:07 PM
Without any addons?
03-06-2023 01:00 PM
@5458 wrote:Can I receive US incoming calls?
For receiving phone calls, it doesn't make a difference to you where a call comes from. If you're asking about receiving calls while you are in the US, you will need to purchase a roaming add-on.
03-06-2023 12:59 PM
Yes you will. You can receive incoming calls from anywhere in the world.
