reactivate a data plan
davidb7026
I currently have a ipad with cellular it has a public mobile sim card that i am looking to reactivate my service too
darlicious
@davidb7026
Here's some info on pm vouchers if needed until you are able to create your self serve account with the assistance of customer support.
https://productioncommunity.publicmobile.ca/t5/Get-Support/Can-t-Make-a-Payment-or-Update-Your-Card-...
@davidb7026
if you call 611 (or # 1-855-478-2542 or # 1-855-4PUBLIC from another line) does it say your account is Suspended?
If your status says suspended, and you never created a Self Serve account yet, try obtaining a voucher to reactivate your services.
Paying for services..see here: https://www.publicmobile.ca/en/on/get-help/articles?q=vouchers
@davidb7026   Can you login to My Account now?  or have you ever setup the Self Serve My Account since you active in store before?
If you never setup an My Account, use this direct link to open ticket with PM Support and they will need to first setup the access to My Account for you.
https://urlshortner.tiia.ai/XZxMjt
click "Contact Us", click "Click here to submit a ticket".
Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
MrSpock
@davidb7026 hi if activated in store you need to create a self serve account here https://widget.telus.tiia.ai/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&duid=2BXKyAsUGl2N10AVl7w... after it is done you can go in and put funds in there to reactivate your account as stated if it is more then 90 days suspended your account is permanently closed
davidb7026
it shouldn't be longer than 90 days but i purchaced the service at a store front and the system is not allowing me to open an account
As long as the service hasn't been suspended for 90 days, reactivation of the service is only a matter of paying for the plan. If it's been longer.than 90 days, the account has been closed.
