06-10-2026 06:30 PM
Hello,
I have a 8GB Canada wide data plan. I am travelling to USA in the next couple of days and i am not sure what i need to do to use data in the states, I am just going for three days and not planning to use a lot. Do I have to purchase an add-on? if so which one?
Thanks!
Diego
06-10-2026 08:31 PM
log in to your Public Mobile account and see if you have at least 20 Reward Points. If you have 20 Points or more, you can redeem them for the 15 Day US talk/text/data add-on bundle.
06-10-2026 08:24 PM
if you only need data for a short 3 day trip to USA, consider downloading the airalo app to your cell and buying a 3 day USA data esim for less than $20.
https://www.airalo.com/es-419/united-states-esim
06-10-2026 07:03 PM
Thank you, thought would be something with a lower cost as I only need for 3 days. Thanks for your help!!
06-10-2026 06:58 PM
The 2nd and 3rd items have the word Bundle, you can buy that
06-10-2026 06:50 PM
06-10-2026 06:47 PM
It's in a different tab
If you cannot find it, post a screenshot and I can tell you where
06-10-2026 06:42 PM
I do not see "US roaming data only add-on" option
06-10-2026 06:42 PM
"US Roaming - Talk Text (15-day)"
That gives you only talk and text, not data. Do you need data?
06-10-2026 06:40 PM
US Roaming - Talk Text (15-day), is this the right add-on?
06-10-2026 06:35 PM
@Dp66 your Canada data can only be used in Canadayou can buy US roaming Data addon.
Login My Account -> Subscription & Add-on and choose it US roaming data only add-on , or US roaming Bundle (data + voice and text). Choose the amount you need. But roaming data has an expiration of 15 or 30 days and it kicks in immediately , so buy right before your trip
