03-04-2024
07:11 PM
03-05-2024
03:05 AM
computergeek541
I'm using an iPhone 11 and transferring from a physical sim with a different provider with an e-sim from Public Mobile. In the process of adding the eSim, I accidentally closed out of the prompts regarding my eSim installation. Under "Cellular" it said the eSim was installing, then after several minutes, told me installation failed. I tried to scan the QR code multiple times but it kept telling me "Unable to activate eSim". At this point, I restarted my iPhone which did not help the issue. I then deleted the eSim altogether and tried to add it with the QR code again, but I am still getting the same error message. I replied "yes" to the text from my previous cellular provider so I don't have any cell service at all until this is resolved. Does anybody know how to fix this?
09-19-2024 01:27 AM
03-06-2024 02:11 AM
03-04-2024 07:28 PM
My girlfriend tried to purchase the eSim when she was considering on moving to PM. She has the iPhone 13 Max and with her IMEI, PM wouldn't recognize the phone so she opted for a physical sim lol
03-04-2024 07:15 PM
@sctk You will have to rebuy the eSIM from the app . If you deleted the eSIM from phone . Best to call around to local Telus Koodo store to pick up a physical sim and avoid eSIM for just this sort of reason or if you ever want to change phones again you will have to rebuy esim . With physical sim you just swap it out . Then get support to someway the number for you. To finished the activation
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
03-04-2024 07:12 PM - edited 03-04-2024 07:14 PM
@sctk - Since you technically deleted it once, you have to contact CS_Agent for a new e-sim.
EDIT: That is somewhat of the fascinating thing about PM, instant activation but when deleted or get a new phone, user has to get a new SIM. You can get a physical SIM card for $4.99 at amazon or at your local Telus / Koodo / Mobile Clinic store.
⬇️Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for an agent because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
