"Sign In" button shows on top in public mobile community website
rahulguptabit
In public mobile community website, "Sign In" button on top keep on showing even after logged in:
Is this a known issue?
7 REPLIES 7
HI @rahulguptabit
and honest, I don't think they are making any change to the website at the moment, definitely not cosmetic changes.  There are other more "glitch", "bugs" stuff for long time and there has been no fix to them yet
So, open the ticket, but don't expect anything
@rahulguptabit
I suppose you could ask the customer support agents to consider removing that (well, they wouldn’t be able to remove it, but they could push the suggestion forward, I suppose),
However, there are so many things that they could improve that they haven’t touched in quite a long time that I would submit it would likely be low on their list of priorities.
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
HI @rahulguptabit
you can try, but don't expect them to update it quick.  Things move slow here
Please submit ticket with CS agent and ask them to pass on the web team
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
rahulguptabit
Is there any way to suggest this as a improvement feature?
HI @rahulguptabit   true, not good design.  I got confused in the beginning too  🙂
rahulguptabit
Usually web sites, doesnt show Sign In on top rather user's name, instead of "Sign In" text which gives the impression that user is already logged in.
Hi @rahulguptabit
no that is for sign in to My Account and My Reward, move your mouse over  and you will see the options
