03-27-2020 01:29 PM - edited 01-05-2022 10:06 AM
I used the sim card in iPhone 6s for a few month but now it shows "NO SIM". I may just miss some software setting but need help here.
I come back from another country on March 18th and use "airplane mode" when aboard. The last text message I got from public mobile is on March 20th.
The public mobile sim card works fine in another android phone.
I also can use the different Rogers SIM card in this iPhone 6s.
Thanks
03-27-2020 01:39 PM
Try this but doesn't help.
03-27-2020 01:35 PM
@dave8 Take out sim. Turn on your phone. Turn phone off. Wait a little. Put the sim inside, and turn phone one. Such hard reboot should help. Tell is the result, please.
03-27-2020 01:35 PM - edited 03-27-2020 01:41 PM
@dave8 why not switch the SIMs in the 2 phones? Kidding. Try using this method to push through the changes and to confirm and reset the SIM sync to iTunes
1. Insert new working SIM - do not turn phone on (if SIM is already in, turn off)
2. Connect to computer with USB cable.
3. Start iTunes if it doesn't auto run
4. iPhone will switch on. Wait until iTunes registers it and checks for updates
5. Install the carrier profile update (if offered)
Disconnect and reboot. From @luddite.
03-27-2020 01:32 PM - edited 03-27-2020 01:34 PM
Restart your iPhone 6s with PM SIM card insert.
Here is Apple.com support how to fix the NO SIM issue.
