questions as following
yx1997
1. how to submit ticket ticket to the customer service, what is the link?
2.
How can I cancel the redemption
I accidentally pressed wrong, how to cancel and return the points and the redemptions for me?
@yx1997   i am not sure if returning the point is allowed, but please check with support by opening ticket with them
1. Please open ticket via Chatbot (requires access to My Account) using direct link: https://publicmobile.ca/chatbot.
Start by typing "Contact agent ", then click "Contact Us", then click "Other", click "Click here to submit a ticket ↗""
Next, enter your Community login, then enter your question.  Finally use My Account login or 4 digits PIN to validate.
HI @yx1997   to request reversing the redemption, please submit a ticket with CS agnet  at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
­­­Public Mobile Representatives customer support­­­ agents (CSA) can be contacted by either two methods, found here:
2.
See what customer support says when you submit a ticket about this.
@yx1997  see above
