07-19-2022
11:43 AM
07-20-2022
03:08 AM
computergeek541
07-19-2022 01:16 PM
There are different kinds of PUK codes. What exact error message is showing on the phone?
Have you been using SIM pin for security and you forgot the code? If it is, then yes, PM Support can provide the PUK code for the SIM card lock.
Please use this direct link to open SIM PIN PUK related ticket
https://urlshortner.tiia.ai/Oyn1L6
07-19-2022 01:11 PM
go to your private messag type CS_Agente to get support team,
07-19-2022 11:55 AM
Most likely you PIN code is entered incorrectly multiple times and hence locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
You will need to open a ticket with PM and their Customer Support could assist:
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
07-19-2022 11:45 AM
@free1reigns hi if you sim locked your phone
contact customer service.
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
