public mobile sim card and iphone 6
Saira
Hi, if i order your sim card can i use on a iphone 6?
ZfromVanC
I just signed up with my iPhone 5s and everything worked. Your iPhone 6 should be fine.
TMG33
Hi , iPhone 6 will work just fine , if it works on Telus network it will ,99% work on public as they are the same company family
If it came from a Canadian provider then it should be no problem.
I don't think they used GSM back then in those phones for Rogers.
Currently stocked Public Mobile sim cards can be used in all three sizes.  You simply need to detach the part that you need.  You will need to first make sure that your device is already network unlocked.
