05-03-2024 10:19 PM - last edited on 05-04-2024 01:27 AM by computergeek541
Not sure when and how I get this 2GB Data Bonus, it is not in the "Add-Ons Usage" tab but in it's own "Promotions Usage" tab. It also says "Promo Cycle: 1/1"
Question: is this one time or recurring Data Bonus? Does it expire?
05-05-2024 04:53 AM
Did you suspend your account for a period of time (up to 89/90 days) before this bonus data add on appeared under the "My Promotions" tab in your account? If so then you recieved a "mystery" bonus add on after reactivating your account. It's likely based on your original plan at activation. I suspect it was a plan priced between $30 to $40 based on the 2gb of data.
05-04-2024 05:44 PM
05-03-2024 10:26 PM
@ETT333 - It should have days remaining which it doesn't so that either means one of two things
OR
So just you can use it up. Also have you been with More is Merrier "Holiday" bonuses? It looks like the calling add-on is from one, which explains why the 2GB is there.
05-03-2024 10:25 PM
it said 1/1, so it is a one time promotion. You never see that before and it just show up this month? usually Promotion Usage or My Promotion are for those activation bonus. When did you join PM?
