porting
wasbandit
I registered yesterday with Public,they sent a request to my old provider to port my numbers (my wifes and mine)
but we never recieved a sms from rogers.
Now theyre saying I need to get Public to resubmit authorizion form for portib.
How do I do that?
Alexandf
@wasbandit
open ticket with PM support and ask them to check it for you.
 At https://publicmobile.ca/chatbot.
Start by typing "Submit a ticket", then click "Contact Us", Then click "Other", then click "Click here to submit a ticket
have trouble with Chatbot: Private message CS_Agent
JL9
Yeah as long as your Rogers account is in good standing and you have your rogers sim in your respective phones it should be a quick process. You can them to reinitiate the process and get that porting text. Just make sure you answer YES asap and it should be seamless after that.
dust2dust
The added detail to the above is that you need to have the OLD sim in a phone to receive the text.
@wasbandit
 Yes it is a critical part to porting is to receive a text from your old provider and reply YES within 90 mins.
There is a number to all to talk to live support and the can re-trigger the process for you.  I will message the number to you via the Community inbox.  Check the envelope icon on top right.  Call them and get it fixed
