09-09-2025
09:28 AM
09-10-2025
11:24 AM
Dunkman
I currently have a plan for $34/mo which is 50GB Data Canada - US., 5G speed, unlimited Canada-US messaging.
I'm doing a one-time travel to Mexico for 10 days. Apparently there is no Mexico roaming add-on. I noticed that there is a pan for $40/month which is Canada-US-Mexico 20GB plus 40GB bonus. I could change to this plan, however, after I get back I would only have 20GB going forward and be paying $6/mo more.
Any suggestions
10-16-2025 03:05 PM
hi @Allan7
are you using the app or browser?
Please try again using Incognito/private/secret mode on your browser to login My Account.
And try the app. There is a new update to the App, so logoff the app first, then update the app, and re-login and try
10-16-2025 02:44 PM
I tried to change my plan to the Canada-US-Mexico one, however, I keep getting "Loading" when I try accessing my Account information
09-22-2025 08:19 PM - edited 09-22-2025 08:25 PM
The $40 plan in your change subscription should be 60 GB and should not reduce to 20 GB after 1 month.
However, once you switch from $34 to $40, it will be extremely unlikely for you to be able to switch back to the cheaper plan in the future. Better just by a temporary travel e-sim for Mexico.
09-09-2025 04:11 PM
hi @Allan7
you likely won't be able to change back to the plan you have before. So, if you are ok with that, make the plan change
if not, you will have to use Travel data sim or travel esim then
