03-19-2017 03:48 PM - edited 01-05-2022 01:51 AM
i am unable to afford my full plan this month. I was trying to change to a 30 day provincial calling, global text with 1 gb of data. this should be 42 dollars and i have put that into my account. i cannot select or change to this plan currently. i would greatly appreciate help with this. thank you,
nathan
03-20-2017 11:35 AM
Hey @dollarmatian,
I'm sorry to hear about your payment issue! Could you send me a private message with your phone number so I can take a look at this for you?
Thank you 🙂
03-19-2017 07:32 PM
@dollarmatian Forgot to add:
Meanwhile, if you need to make phone calls try an application like that from fongo.com. It provides free calling across Canada from wherever you are connected to wifi, or on cellular data.
03-19-2017 04:14 PM
This seems to be a known "issue" in Self Serve. I hope the mods can get you back up and running with the services you want soon. It has already been suggested that this issue needs to get fixed soon.
03-19-2017 04:09 PM
a) don't add any money for the taxes; they will be billed to your credit card
b) you MUST contact a moderator as that is the ONLY way to change your plan once it has gone into suspension
03-19-2017 03:59 PM - edited 03-19-2017 04:02 PM
Go ahead and contact a moderator, they should fix your problem.
I will tag one of them for you
Also to clear it up more the price for the plan is 42 $ + taxes, so don't forget about the taxes
Here is how to contact a moderator
Edit : typos, + taxes
