phone
Oscar9
phone don't ring calls go direct to voice mail
slusagm
@Oscar9
can you make calls? can you receive incoming text? mobile data works?
if you just joined PM with roaming, that could be a incomplete port.  Put the old provider sim in a phone and test, if it works, then yes, porting was not done.  Open a ticket with PM and they can help
but if you are existing customer, and only voice calls are having problem, then it might be due to the recent VoLTE issue. Check if your phone is VoLTE whitelisted by PM here:
https://www.publicmobile.ca/en/on/get-help/articles/volte
Chalupa_Batman
Does this happen for all calls or only certain calls? Did you turn on a call feature and not realize it? Or maybe a software update was done and it automatically turned on a call screening setting?
ORNGNBLK
@Oscar9  Are you a new subscriber and this is a new issue? Have you ensured to remove old carriers physical SIM card and replace with PM sim? If e-sim, make sure PM e-sim is set to primary. Try resetting network setting and reboot phone as well. Hope this helps
