phone plan
11-04-2021 11:19 AM - edited 01-04-2022 05:16 AM
hello, im currently trying to help my 82 year old father who is having issues with his phone. He is in florida and just updated his plan to include international calling while hes there. Since he add this feature his phone losses connection after 3 minutues. he is frustrated and so im asking on his behalf.
his phone number is*********************
ArtVanvliet
Service
11-04-2021 03:35 PM
Do you have access go your father's self serve account? Can you act on behalf of him with customer support? @Nezgar has likely identified the issue. Even if there isn't two US roaming add ons overlapping with a talk feature perhaps adding the international calling add on caused this same glitch. You can ask the CSA to remove it if your father does not need it normally as it will only work while in Canada anyways and they will credit his account. You may want to suggest to your father an international calling card available at local shops for those needs.
It may be easier for you to contact customer support via private message using your father's account details.
Send a private message... Contact the CSA's (formerly moderators) by sending a private message and leave a detailed message explaining your issue and the info to verify your account by including the following information:
- Full name and address on pm account. ( Or province and postal code for newer accounts.)
- Email, phone # and pin #.
If you cannot remember your pin # include at least three ( if they apply)of the following:
- Date of birth (n/a on newer accounts.)
- Last payment, date, amount, type and last 4 digits.
- Alternate phone number if any.
- Security question and answer.
- Plan amount, any add ons or promos on account.
- Last 4 digits of sim card.
- Any rewards in your account.
- Autopay y/n?
- Account #.
- Frequently called/texted phone numbers in the last 30 days.
The average wait time is 2 to 4 hours but be prepared to wait up to 48 hours for non urgent requests. Current wait times are about one hour and are probably even less as I have had some very quick responses in tne past week.
Keep an eye on your private message box the envelope icon next to your avatar for a little number to pop indicating a message from the CSA's (formerly moderators.) Responding promptly will speed up service times.
Do not post any of this info in the community only in your private messages when communicating or contacting the Moderator_Team.
To send a private message to the CSA's (formerly moderators) click below
: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
11-04-2021 02:16 PM
@ArtWVanvliet wrote:Since he add this feature his phone losses connection after 3 minutes.
Can you or him login to the selfserve portal and check which specific add-ons are present on the account? I believe if more than one U.S. Roaming add-on that includes voice is added, it will cause this 3-minute drop issue. You may need to open a ticket with a CSR to remove one of them.
U.S. Roaming add-on's provide calling to Canada and USA. I think an International calling add-on will only allow calling to those additional countries if the phone is in Canada, not USA.
11-04-2021 11:56 AM - edited 11-04-2021 11:57 AM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
- Open the Settings app on your Android.
- Scroll to and tap either "General management" or "System," depending on what device you have.
- Tap either "Reset" or "Reset options."
- Tap the words "Reset network settings."
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
11-04-2021 11:47 AM
Do you know if he's calling domestic US numbers or to another destination? Is it always exactly 3 minutes the calls are dropped?
If he's down in Florida for a while or regularly visits, you might consider helping him get a US-based service. Mint Mobile comes up a lot, but other providers like AT&T may have prepaid or other options that may work well too.
11-04-2021 11:38 AM - edited 11-04-2021 11:56 AM
@ArtWVanvliet wrote:sorry yes it is a roaming package...wither way since he update his plan his phone drops calls after 3 ,minutes
Ask him to try putting the phone on 3G-only (WCDMA) to see if it helps.
Can also try reinstalling the SIM card, or try it in another phone to see if it gets better reception.
Edit: Your father can also use a voip like Textnow if he has good access to free wifi.
11-04-2021 11:34 AM
First steps.
Choose best network to roam on. How many bars does he have?
Reboot phone.
11-04-2021 11:31 AM
So you able to make the calls but it always dropped after 3 minutes?
US roaming uses either AT&T and T-Mobile. Did you try both networks and see which one is better and might not give you that issue anymore?
11-04-2021 11:29 AM
@t_p please help and remove OP's phone number from the quote on your reply
11-04-2021 11:28 AM
11-04-2021 11:28 AM
@ArtWVanvliet wrote:hello, im currently trying to help my 82 year old father who is having issues with his phone. He is in florida and just updated his plan to include international calling while hes there. Since he add this feature his phone losses connection after 3 minutues. he is frustrated and so im asking on his behalf.
his phone number is xxx-xxx-xxxx
ArtVanvliet
@ArtWVanvliet Please update your post to remove the phone number. This is a public forum and you don't want too much info posted online
As to your father issue, does he has US roaming? Using the phone in US require US roaming.
However, if he is there long, it would be better to join som local prepaid plan instead. Cheaper and more data or minutes
11-04-2021 11:28 AM - edited 11-04-2021 11:30 AM
11-04-2021 11:26 AM - edited 11-04-2021 11:31 AM
his phone number is xxxxxxx
ArtVanvliet
The international calling only works if the calls are made from Canada.
What your father needs is a US Roaming package:
Plans (publicmobile.ca) > Add-ons > US Roaming 10 day packages
