01-11-2018 12:36 PM - edited 01-04-2022 03:17 PM
hello i am intrested in your services... but i am woundering if i switch to your company can i keep my current phone number ?
01-11-2018 09:40 PM
I switched over today and I had my number transfered over without issue
01-11-2018 04:17 PM
Yes, you can and most people here ported their number from other provider.
before you port your number over, make sure you have you current account number, your name on the account and PIN number for that account. for the pin number if you don't know, call the customer service to find out. the pin number is very important.
01-11-2018 03:01 PM
You weren't able to back in the days, but telecommunication laws have changed since then.
01-11-2018 12:46 PM
To expand a bit on the comments already, porting is able to be completed by you during the activation process, or after you have created an account with a new phone number (the second option is the recommended way to do it). You need to ensure your account with your old provider is in good standing and then the process of porting is a breeze following the steps.
Have a read of the following link for the best practices to ensure a smooth and successful port-in.
01-11-2018 12:41 PM
Yes 99.9% of the time
01-11-2018 12:40 PM
Hi @sparkplug,
Yes, if you switch to Public Mobile, you will be able to bring your existing number over to Public Mobile as well (this process is called phone number porting).
