05-06-2019 04:26 PM - edited 01-05-2022 04:48 AM
It does not work. Tried doezens of times, fed up
05-06-2019 04:28 PM
@Benzai You are allowed to change your number once every 30 days. If you ported or changed your number recently, you will have to wait. If you did not port in or changed your number within past 30 days and you are not able to, send a private message to the Moderator_Team and they will try from their end.
