09-16-2022 07:21 AM
I have my credit card on file.....issued payment....twice bought voucher.....phone still will not connect to network
09-16-2022 09:57 PM
Go to the Get Help pages: https://www.publicmobile.ca/en/on/get-help
Then type "customer support" in the search box.
You will see all the Customer Support Agent information there.
09-16-2022 09:21 AM
where is customer service located
09-16-2022 08:39 AM
7am what time zone
09-16-2022 08:38 AM
@ChrisSteeves98 honest, the helpdesk open at 7am. I would message them once again and "remind" them there is a ticket pending. Just message them
09-16-2022 08:34 AM
Thanks,
great! I have been waiting 3.5 hours for this to be taken care of.....gawd! I missed a shift at work!
09-16-2022 08:31 AM
@ChrisSteeves98 wrote:YES I DID schedule a plan change on the date of renewal.....has this been rectified for other users.....i am going to switch providers if this is not taken care of as I use my phone for work!
@ChrisSteeves98 You got caught with the "Gltich of the week" 🙂
Open a ticket and they will resolve it. One member mentioned that they resolved the problem quickly.
09-16-2022 08:26 AM
09-16-2022 08:23 AM
sim does not work in another phone but another sim will work in this phone
Ok, now it look like either a sim card problem or account problem.
Did you schedule a plan change on your renewal day and renewal day was yesterday? There have been some problem with situation like that yesterday
either way, open ticket with PM Support first:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
09-16-2022 08:13 AM
Account states active....says I have a 50 balance on my account (this makes sense since it was paid via credit card & I added a voucher just incase)
samsung 20fe has been on Public Mobile since december 2021
rest phone to see if it would "grab" the network.....nope
09-16-2022 07:51 AM
@ChrisSteeves98 wrote:I have my credit card on file.....issued payment....twice bought voucher.....phone still will not connect to network
@ChrisSteeves98 phone still not connected to the network could be a technical issue and not payment issue
When you login to My Account, do you see the account status showing as Active? if so, it is not a payment issue
Now, check the phone.
First, what brand and model is the phone? did it ever work on Public Mobile network before? Did it ever able to connect here?
Try to reseat the sim card. Power off, take sim out for a minute, then put it back and power on
Next to try , put your PM sim card in another phone and see if it works
Also, you can try to put another active sim card from another carrier to your phone and make sure it is not a device issue
let us know the result and we can try to help further
