phone didn't ring when get phone call
xiao1
I can only get the phone call from my contact list. My phone didn't ring at all when people's phone number other than my contact list. I was looking for a job, and I missed couple of phone calls from the industry. How can I fix it?
xiao1
Thank you very much.
xiao1
Thank you very much for your help.
@xiao1
If it is an iPhone, disable Silence Unknown Callers in Settings>Phone>scroll down to SUC and turn off.
hi @xiao1
iPhone or Android?
it is a phone settings, you have enable the spam call control feature.
On iPhone, it is called Silence unknow callers (Settings -> Phone screen, disable it )
On Android, it might be called Block calls from unkonwn numbers
