phone calls not made by me
Panlo
out going number 647-580-4001 not made by me
Tmoney
Thanks 😊
HI @Tmoney  and @Panlo
that is the number for voicemail.  PM will show that if you called your voicemail or people calls gone there
Tmoney
Can you elaborate what you mean by this ? Are you saying that other people are reporting receiving calls from your number , but you did not make the call?
If so, it's possible someone is using a number spoof to show your number on caller ID when calling. This is a common thing that scammed do ( make it look like they are someone else). No one is immune to this
@Panlo
this is Voicemail number.  PM record all calls going to VM as well
Basically, if you call VM from your phone, or if someone called you and got routed to VM because you didn't pickup the call, those will be shown on the Usage history .
So, no worries
@Panlo  No worries  that’s just a voicemail number PM uses when you call your voicemail
