payment
02-03-2022 09:18 AM
02-03-2022 12:06 PM - edited 02-03-2022 12:09 PM
You sure on the credit card, both charges are completed charges and not 1 pending charge and 1 completed?
did you just activate last month? Do you recall you had issue with activation and you have to re-attempt activation a 2nd time? If so, I am wondering if you activated twice by accident
Can you login to My Account and check what is showing as Available Fund? is it $0 ? or $25?
Let's jump back to your own thread:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Payment/td-p/782810
02-03-2022 11:38 AM
My credit card statement showing l paid twice last month but it is not showing in my account.
02-03-2022 11:19 AM
If you have enough funds and is on AutoPay. You are fine, notice will show on your Self Serve account just before your payment is due.
02-03-2022 10:52 AM
So what is your question?
Do you have service? Are you on autopay with registered credit card?
02-03-2022 10:30 AM
Do all your services work?
If so, and you are on auto pay with a valid payment card or have an available balance equal or greater than your plan amount, you need not do anything.
02-03-2022 09:53 AM - edited 02-03-2022 10:03 AM
@2201 So, it's not due yet, then. You still have phone service without interruption, right?
Renewal process will start tonight around 6pm (yes, it is a long process , it starts around 6pm the night before but they won't actually charge anything till after midnight)
So, is $28 enough to cover your plan (you are on $15 or $25 plan)? If so, then no worry. You have enough fund in the Available Fund. When they start the renewal process, they will take money out of Available fund and won't charge your credit card again
curious, you have Autopay enabled ? If you are on the old reward system, have Autopay enabled to save $2 per month
02-03-2022 09:45 AM
now says I have 28.00 balance but payment due Feb 4. Also says I have enough funds now but originally couldn't make a payment
02-03-2022 09:22 AM
Is your plan active right now? Is your phone working? When was your payment date?
If phone not working, manually load up funds equivalent to your plan's fee. That should restart your plan.
02-03-2022 09:21 AM - edited 02-03-2022 09:23 AM
@2201 is the payment due this morning? are you still having phone service now? If you still have phone service and if My Account account status showing Expired, then let's wait for couple more hours. PM has been taking longer to renew these days and it could still be renewing
However, if you already lost your phone service, check My Account, if account status showing Suspended but your Available Fund = Plan Amount, then let's do a trick to trigger the renewal
Go to My Account->Payment Tab->One time payment:
https://selfserve.publicmobile.ca/Overview/payment/Make-a-Payment/
and make a manual payment of $1 (using the option Other (Enter the desired payment amount) from the pull down) . Once the payment gone through, check if "Reactivate current plan" button is there and click on it
then logoff My Account and reboot your phone
However, if your account is Suspended but Available Fund = $0, then you will have to follow the above manual payment steps and manually enter the Plan payment amount (instead of just $1)
