payment accepted
drmcat
I had problems last payment. Payment was accepted but I was getting no phone use. Some one suggested that I take sim card out of phone and then put back in. That fixed the problem. This month same thing happened. So I took out SIM card and put back in this time it did not correct. What do I do now
2 REPLIES 2
Yummy
Maybe it is not SIM but your phone?
Can you try your SIM an any other phone?
Can you try to clean contacts inside the phone and SIM's contacts?
Phil_Adelphus
@drmcat  Can you try your sim in another phone, and also try another working phone's sim in your phone?  That will help narrow down whether it's a sim problem or a phone problem.
