08-17-2022 02:56 PM
hello. I tried to reset my password, all seemed good. went to login, didn't recognize new password. maxxed out login attempts. Please help. Thanks.
10-04-2022 08:32 AM
And you should not have to clear your browser, use a different browser, etc... I have many password reset options on many services and this is the only broken one.
I do not mind self serve... is the self serve tools work.
08-17-2022 03:06 PM
Thanks, tried different device, incognito etc. Will submit ticket.
08-17-2022 03:02 PM
@pjminns hi did you try clearing your cache and cookies or try a different browser in ingognito or sercret mode reboot and try again also try a different device if one is available
08-17-2022 03:02 PM
close all browser and tried use browser from computer, clear cache and cookies and use one page inPrivate mode,
To Login Page
08-17-2022 03:01 PM
HI @pjminns
if you already tried Reset Password and fails, please open ticket with CS agent and they will reset it for you
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
08-17-2022 03:01 PM
@pjminns You can try waiting an hour before retrying to reset the password but clear your browser cookies/cache and use incognito mode or a different browser.
