overpayment
Dumy
I changed  my bank account for autopay and I am paying usually around $12  however I got charged for$16.
darlicious
@ace_phone
Did you switch to the points program? If not are you saying your card is getting charged $60 each renewal and your rewards are not being applied? Check your transaction history and report back.
ace_phone
Did you get this sorted out?  I'm having a similar issue. My plan is $60, so the autopayment is $60, but I have monthly credits for autopay, refer-a-friend, etc that add up to $20. So I only owe $40. I've been building up credits every month. I wonder if you are in the same boat?
@Dumy   What is your usual plan amount?
I do not think you are , but $10 plan is now $13 (but  you should have some loyalty rewards and you shouldn't be paying full amount like that)
If possible, go to Transaction log ( https://selfserve.publicmobile.ca/Overview/payment/Payment-History/ ) and gie us a screenshot  of the last 2 months so we can tell when you are paying more
@Dumy - did you do a top up payment when you changed your bank information?
Check your payment history here: https://selfserve.publicmobile.ca/Overview/payment/Payment-History/
If the funds are showing paid and added to your Available Funds area, then those $'s will be used on next renewals.
OR, are you saying you usually pay $12 per renewal, but now you are paying $16? Are you taking into account the taxes, which do not show in your self serve but will show on credit card charges/debit visas.
darlicious
@Dumy
Have you used lost/stolen in the last 30 days?
Edit:
Or switched and joined the points program?
