11-05-2023 07:09 AM
november 3rd 51.75 was my initial visa payment then i received the same bill for november 5th twice
How can I get the extra two billings taken off my visa
11-07-2023 02:18 PM
Yes, the term "ticket" should be wiped from this site for as long as the ticketing system is not working. Use the link provided in that previous reply to contact support.
11-07-2023 02:16 PM
ok not sure how to open ticket
11-05-2023 07:54 AM
@abdouc so, you activated a new account? Could be a problem during the process, I would message support and ask them to investigate
11-05-2023 07:48 AM
I will try later your advice.
thank you
11-05-2023 07:46 AM
Hi softec yes I saw the amount and it is under authorized transactions. Does that mean pending? In facT i see three of them.one dated for nov 4th and two for nov 5th.
Ii bought the sim card online in the amount of 51.75. i dont understand why I was billed an extra two times using the same sim card?I am not computer savy thinking it could be easy peasy.
11-05-2023 07:19 AM
@abdouc did you. see the same charge on your credit card? Any chance one of the just a pending one?
And login My Account using Incognito mode and check if you see the extra money sitting at Available Fund
if both are real charges and you don't see where the extra money went, please open ticket with PM support
