03-02-2023 05:24 PM - last edited on 03-02-2023 06:04 PM by computergeek541
i dont know how they are running this mobile company- its 30yrs backwards
03-02-2023 05:44 PM
@paul27 - there is more than one way to contact an agent (Public Mobile Representatives customer support agents (CSA)). Check out the Get Help articles and seach "customer support". you find the methods there:
03-02-2023 05:27 PM
@paul27 try using 4 digits pin to validate instead of username
if that still does not work, message PM support
03-02-2023 05:26 PM
I think they're pretty good. I've been with Public Mobile for 2 years now and I haven't had any major issues. Plus, where can you get 15 gigs for $40!
