not able to login via phone to community
mimmo
Just wondering if anyone else is having issues ogging int the forums from their phones.  I click login and the form appears enter info, and then i just get the regular page as if i have not logged in. no password error or anything. this seems to happen also with self serve.
Probably just a me issue else i am sure this would have been mentioned before.  Just thought I woudl ask.
using android HTC M8 android 6.0, havve rebooted phone a couple times.
thanks in advanc for any suggestions.
dom
7 REPLIES 7
SD08
@mimmo wrote:
Thanks for the replies, and confirming its a "me issue"
 @SD08cache is cleared, hadn't thought of that. (no effect)
Will try logging in using wife's phone when i get home, (she has same one).
Just an update.  ( I had cleared cache from apps settigs, not from chrome itself, once i cleared it from inside chorme all was fine.)  I should have looked at the link you sent me a little closer.   🙂
I had that problem before and I usually found clearing the cache solved it.  Glad I could help.  Smiley Happy
zhadj030
This only happens to me when I try to access the community from this link rather then link on the main page
http://community.publicmobile.ca/
Chaos_Scorpio
Don't you mean it is a "mi issue" ... (sorry I had to Mimmo) 😛
mimmo
ShawnC13
@mimmo, no issues here on  my Lumia 950XL  with Win10 Mobile OS and Edge browser
I'm assuming since you're using and android, you;'re also using Chrome browser?
Possibly try downloading a different broswer and giving that a try.
SD08
@mimmo
I have no problems with either the community site or the self-serve login.
Have you tried clearing your browser cache?
http://www.wikihow.tech/Clear-Your-Browser%27s-Cache-on-an-Android
