no texts or calls
cmcdonald7
hi guys,
my wife's cell stopped working this am out of the blue, no calls or texts. suggestions?
8 REPLIES 8
wjhzlz162
It’s helpful. Thank you!
First look at your My Account for any irregularities and reboot phone.
JL9
😖Hope that's not a regular occurrence 🤞🤞
@cmcdonald7
Check to see if there are any outages in your area:
https://www.telus.com/en/qc/outages
Looks like lots in Alberta and one in BC.
hairbag1
@cmcdonald7 wrote:
hi guys,
Somebody had a similar issue earlier today...after an hour, it was working again. Could be a local outage issue.
Log in to account to ensure it's Active.
Try the sim in a different phone to see if maybe the phone is problematic.
Let us know if anything helps.
edit...I gotta learn to type with more than just one finger...if I wanna get in ahead of @softech .
@cmcdonald7   I would first confirm if your My Account is status Active or not
If it shows active, try to reseat your SIM (power off, take sim out for a minute before putting it back and power it on)
If still fail, try to get another phone and put the PM SIM into it and test
Let us know if it works
Lovely2
@cmcdonald7
try to do rebooting phone
BeachNBeer
@cmcdonald7 log into the account is it active or suspended?
Also was phone purchased second hand? If so check devicecheck.ca to make sure it's not blacklisted.
Let us know!
