no signal
03-16-2021 04:37 PM - edited 01-06-2022 02:19 AM
i'm having some network issue, there is no signal on my phone. i tried to reset the network setting, but it didn't worked. i even tried to take off the sim and reinsert it, got the same result. did couple of rebooting, still not working.
i am using an Android,
Service
03-16-2021 06:10 PM - edited 03-16-2021 06:14 PM
@PK4 wrote:i'm having some network issue, there is no signal on my phone. i tried to reset the network setting, but it didn't worked. i even tried to take off the sim and reinsert it, got the same result. did couple of rebooting, still not working.
@PK4 Presume you HAVE HAD service and you LOST it?
Please make sure that your device is unlocked.Check your phone's compatibility with the Public Mobile network.Make sure airplane mode is toggled "OFF"Tap on the following: Settings, System or General Management, Reset or Reset Options, Reset Network SettingsCheck self-serve to ensure service is Active and not Suspended
If none of this works, you may need to contact Moderators for assistance or explanation.
03-16-2021 05:47 PM
@PK4 wrote:@Anonymous : it means i have to change my phone now?
If you prefer to stay with this place and use your phone for talk then yes.
Of course Telus wants you to move up to Koodo or Telus but another phone would do the trick too. Just move the SIM over to the other phone and you're away. You need to look at specific specifications of other phones if you wish to stay. ie. 1900 3G for talk. Or come here and ask and someone can say it would work or not. Just provide the full make/model/submodel of what you're looking at.
03-16-2021 05:43 PM
03-16-2021 05:40 PM
@PK4 wrote:@hTideGnow currently i am using Android, device name is Realme 2, Model no. RMX1805
You were barely holding on to PM with that phone. Even LTE. You have 850 3G. They dropped that. The other frequency is 1900 which you don't have.
03-16-2021 05:39 PM
@esjliv no, not at the moment.
03-16-2021 05:38 PM
@PK4 , do you have access to a different phone to use?
03-16-2021 05:38 PM
@Anonymous , @PK4 RealMe 2 only has the B5(850) channel , do you know what is the only channel left on 3G for PM?
03-16-2021 05:33 PM
03-16-2021 05:25 PM - edited 03-16-2021 05:25 PM
@PK4 wrote:@hTideGnow : did public mobile halted their services in Winnipeg ?
As I understand it, they've re-purposed one of the 3G talk frequencies leaving just one frequency that PM uses. But the towers in your area would need to have that frequency. Which is why I asked what specific phone you have.
03-16-2021 05:23 PM - edited 03-16-2021 05:24 PM
What is the impact?
Only customers in Winnipeg and Brandon will be impacted. Only certain Hz bands will be changing, which will impact the quality of voice calling and service. Data speeds will remain unchanged.
You know what, from what it said, you should at least have Data service. Voice might be affected but not data.
Try putting your SIM in another phone if possible and see if you can have voice and/or data.
03-16-2021 05:20 PM
03-16-2021 05:18 PM
@PK4 : Well...there you go. What exact make/model/submodel phone do you have? Maybe flip in/out of airplane mode to maybe find different frequencies. Not sure if that'll work and also whatever your phone is would need to be compatible.
03-16-2021 05:17 PM
@PK4 , sound like you might be in the affected area. Best to check with Mod to confirm. If that is the case, Koodo/Telus or other providers might be your only choice.
03-16-2021 05:15 PM
@Anonymous yes i did
03-16-2021 05:10 PM
Oh no. we have one "casualty" now.
03-16-2021 05:09 PM
03-16-2021 05:04 PM
winnipeg, MB
03-16-2021 05:02 PM
@PK4 ,
Are you new to Public Mobile?
Did you just activate a SIM card?
Did you activate a new number or Port one over?
If you are not new to Public Mobile try toggling into airplane mode for a few minutes, then back to regular mode.
You seem to have have done some trouble-shooting. Ensure your Self Serve account is Active. Then I would check with the Moderators to ensure your SIM card is up to par and your account is all good.
Some info. to review regarding SIM swapping:
https://www.publicmobile.ca/en/on/get-help/articles/sim-swap-fraud
To contact the Public Mobile Moderator_Team, there are two ways to reach them:
1 - Faster Method - Click the bubble comment circle on the bottom right hand side of your screen, or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower Method - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
03-16-2021 04:51 PM - edited 03-16-2021 04:51 PM
@PK4 Is your account active (no issues with suspended account for lack of payment?), or perhaps there may be an outage in your area?
BTW what plan are you on? There have been a few threads reporting issues and they all seem to be on the $15 plan, which may be related if you are also on the same plan. If that is the case then you'd need to contact moderators by submitting a ticket via chatbot here: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
03-16-2021 04:41 PM
Which province are you at?
Try put in your SIM into another phone if possible to confirm if it is a account/SIM issue or if it is phone issue.
