no service
06-19-2019 10:46 AM - edited 01-05-2022 05:27 AM
Hi,
I activated my sim card yesterday and it shows no service. I have an Iphone 7. The phone is unlocked from previous provider. I have 50$ for available funds. I did remove sim card and put it back, switch the phone on/off, still nothing.
It's searching on public mobile or automatic mode for a few seconds and show no service.
Someone has an idea about the next step?
Joining Public
06-19-2019 01:24 PM
The number appears correctly in Plan and add-ons!
When I called with another phone, it says it's out of service 😞
06-19-2019 11:57 AM
06-19-2019 11:49 AM
I did contact the Moderator team!
06-19-2019 11:47 AM
Ans when I go Settings - General, Public mobile carrier shows up, but I noticed that in the Network, it says Not available - "SIM not provioned".
Maybe that's the problem?
06-19-2019 11:43 AM
I have the $40 for 30 days plan.
06-19-2019 11:00 AM - edited 06-19-2019 11:04 AM
@yashone1you have $50 in available funds but do you have a plan? Having a plan is more important than having funds.
If you do have a plan, try your SIM card in another phone.. if it doesn't work then contact the Moderators. I would peg it to a bad provisioning.. it happens.
06-19-2019 10:59 AM - edited 06-19-2019 11:00 AM
@yashone1 wrote:Hi,
@yashone1Others have reported by plugging it into iTunes and downloading updates will resolve the issue. Might be worth a try.
06-19-2019 10:56 AM
Does your plan show up in the overview page?
50$ in available funds???? What plan did you purchase and how much was it? Was it a $60 plan by chance?
New activations should have at most $2 available funds(autopay credit) if activation went properly.
Is it possible you had a bad activation? Can you post a screenshot of payment history?
You could try the lost stolen trick toggle lost stolen mode for a minute click plans and addons then lost stolen. Then the report phone as lost.
06-19-2019 10:51 AM
@yashone1 wrote:Hi,
@yashone1 Click here for info on how to resolve most iPhone issues.
