SIM card not working properly
Reimer
Bought a sim card, started activation made it to the page where I pick my number, but there was some technical issues with the site so I wasn't able to finish. Now when I try to start over it says the sim card is invalid. What to do
Mike40999
Messages moderator for help !!
choding
I don't know what kind of web browsers you used?
befor you use it, go to the history and erase the any histories as you have, it means you have to clean your browser. And try it again.
I thought the messed cach caused some problems to activate.
thanks
Reimer
Thanks. Worked like a charm
sonatinamegan
This happened to me as well. I had to refresh the entire session, close my internet tab completely and start over..I hope your issue gets resolved!
popping
@Reimer
Close your browser and start over your activation again.  It should work.  I was using Opera browser with ad blocker enabled.
I also used Chrome for another activation without issue.
Dunkman
@Reimer
The website is finicky after a failed activation.  Some people have tried a different internet browser, incognito mode or clearing the cache.  Also, sometimes waiting one to two hours and trying again would work.
