08-01-2019 10:22 AM - edited 01-05-2022 06:13 AM
Hi, all of a sudden today, my phone doesn't work, no data. I don't think i went over, it is impossible, as I did not use my phone differently than any other months. I am wondering if this have to do with my add on roaming plan last week?! But that shoudln't affect it, and I feel like there was some error. Please get back to me ASAP, as i cannot use my phone.
Thanks.
Phones
08-01-2019 10:50 PM
Moderator never resonded to me. I just read this msg. Can't attach or paste the screen shots, but do u know if when romaing. Data still still show on the usage history?
08-01-2019 11:17 AM
@Katwu wrote:Thank you, kindly.
While you're waiting...and waiting
maybe post a screen snip of your overview page so we might be able to decipher what you see. Blank out personal info of course.
Have the roaming add-ons expired yet? If they have then there might be no need.
08-01-2019 10:59 AM
Thank you, kindly.
08-01-2019 10:54 AM
@Katwu wrote:That's what I'm saying...the data usage is showing up on my 'usage history' during romaing time. do yow you know where I can find who is the moderator?
To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderators are available: M-F from 8 AM to midnight Eastern time and S-S from 8 AM to 10 PM Eastern time.
Note: Moderator Hours are subject to change, but you can always find the current times here
08-01-2019 10:51 AM
08-01-2019 10:45 AM
08-01-2019 10:41 AM
@Katwu wrote:I did review my data usage, and from the 5 days I was not in the country, and had an add on romaing plan, those days I had data accounted for, which should not have, correct? Or, does the data still show for the romaing package?! I know, as a fact, there is no way, I went over my data usage...
@Katwu If you are referring to a US roaming add-on that includes data then you are correct that bucket gets used when you are in the US. Same answer though check your usage logs. If you still think there was an error reach out to the moderator team for more clarification.
08-01-2019 10:38 AM
08-01-2019 10:29 AM
@Katwu wrote:Hi, all of a sudden today, my phone doesn't work, no data. I don't think i went over, it is impossible, as I did not use my phone differently than any other months. I am wondering if this have to do with my add on roaming plan last week?! But that shoudln't affect it, and I feel like there was some error. Please get back to me ASAP, as i cannot use my phone.
Thanks.
@Katwu The easiest way to determine if you ran out of data is to login into selfserve and if you see a data counter on the landing page then you still have data. If not, it means it was used up. Check your usage history logs to determine what happened.
08-01-2019 10:26 AM - edited 08-01-2019 10:27 AM
you need to log into the self account, to see if the data run over. We are all customers like you, could not access to your account. If you need further help, you can send a private message to MOD team, click here.
